Another day, another problem with the ST24...
Started it up, revs rise to a healthy 3000 RPM as normal, then start dropping down to a fast idle, and down... and stutter... and the engine stops.
Tried starting it several times, each time the same. The engine seems to die faster if you press the accelerator (ie, that pedal has the complete opposite of the desired effect), which to my 'non-mechanical' brain doesn't make any sense!
I thought it best to record what happened on about the 4th occasion to illustrate the problem.
What do you suppose is wrong?
http://www.youtube.com/watch?v=qFM8wDMr3Yc
