Monitor CPU temp
2 Oct 2006
I usually use CPU-Z or openhardwaremonitor to check my CPU temp (and everest free edition) but none seem to be reading anything.
If I go into BIOS, I can read the temp no problem.
I use core temp
I have the overheating protection enabled and always leave it 10 or 5C under the cpu Tj max.
What's changed about your setup so they no longer work?
I am more likely now to just use the radeon software as I have it as part of the overlay when playing games, or fancontrol as I use it for fan/temperature control.
Made sure the apps are both up to date?
Apps are like
MSI Afterburner
Core temp
openhardwaremonitor
CPU-Z
Don't know if you can with NVIDIA or not but if you have an AMD GPU you can just use the AMD overlay.
