I've decided I fancy a change from my standard 16:9 Samsung P2450's which I've had in a 3 monitor setup for a while now.
Ultrawide seems to be the way to go, but having ordered and tested an LG 34UM95 from o/c, I've found the resolution is just too intense and makes working from outlook (old version), word/excel documents and general web browsing difficult due to the small text. I tried changing relevant zoom settings etc but they all compromise icons and images in one way or another, and let's face it, why should I!
I've then spotted that LG also do a 34" (34UM65) with the lesser resolution of 2560x1080 which might suit better, but I wanted to know if this would result in a similar font size etc to what I have now (16:9 1920x1080) and given that 2560x1080 is normally used in 29" monitors, will it look terrible on a 34"?
The reason I'm opting for a larger ultrawide screen is that the 29" ultrawide's look a bit lacking in height and the real-estate may not be enough for my needs and I'd then have to get two, which I'd prefer to avoid as I'm hoping to return to a one monitor setup.
PS - I use the monitor(s) for work and pleasure, so a mix of email, documents, web browsing, web/graphic design, gaming and films so a good all rounder is needed!!!
