Monitor for Films
5 Dec 2008
Kent
Hi,
I use my computer as a Media Centre and do not have a TV.
I watch Netflix, Amazon Prime, YouTube etc. on it.
I currently have a 29" ultra wide-screen monitor which is great for watching films in 21:9 resolution and multitasking. However, some things such as text appear a bit too small due to the sofa being over ten feet away.
Does anyone have any recommendations on larger monitors? My budget could probably stretch to £400.
Thanks,
Matthew
You're 10 feet away? Any monitor is going to be too small at that distance. What's the dimensions of the space you have to work with... width/height?
Therein is the problem ... what's optimal when sat in front of it, isn't good at 10 feet.
I could move the sofa a few feet closer I suppose.
I don't know the specific dimensions but I couldn't fit a monitor and a television on my desk.
I do like ultra-widescreens so I can snap a window for browsing on one side and media in the other for my partner (but understand if that is not practical as they are quite short).
What do you mean you dont have a room for a TV, do you live in a shoebox ?
Almost.
As much as I like my current 29" 21:9 monitor I think a 32"+ 16:9 screen would make for a better viewing experience. Plus my aging 7950 3GB GPU struggles when gaming on that resolution.
Does anyone have any recommendations for about £300?
Thanks.
Almost.
Thanks.
There are quite a few 32" 4K monitors around your budget.
Look for VA or MVA based monitors for the decent blacks and good contrast for media viewing. I've had up to 40" 16:9 (flat) and that's pushing the limit sat close up as the corners become remote.
35" UW BenQ monitor I had was great for movies being VA based but was less so for PC use being 2560 x 1080 resolution so I dedicated it to my sim setup. I have a 34" Acer Predator now for mainly gaming and it really only lacks the extra deep blacks for film viewing of MVA so I use the TV downstairs for my "main events".
I just bought a 32" AOC 3279VWF as a general use monitor I move around as needed and it's a good all round spec. at 2560 x 1440 and 75Hz refresh and great blacks being MVA. Not the best monitor out there by far but at £189.99 it was a bargain. VA/MVA can be a bit "muddy" compared to a decent IPS at the lower end but I still prefer the better contrast myself.
Thank you for the tip. That seems cheap for my budget and should increase the monitor size a bit.
Are there any larger monitors anyone can recommend?
Just to add there's a D8 version of that monitor which is IPS rather than MVA and appears to have replaced it now.
