Monitor For UT2004
26 Jun 2007
Wales
If anyone plays UT2004 or UT3 what monitor do you use and do you get any problems with it, I ask because my monitor at it's native res is abit ghosty in the games and i wonder if that's mainly due to the speed of the games.
What monitor do you use?
I was playing both on a Dell 3007 and Viewsonic VX2025 quite a lot with no ghosting.... just got my hyundai 240 - no ghosting again :) All played at native res.
depends what you're using now really.......?
Nice one for the quick replies, I use the Hyundia N220W-D 22"
It seems to be fine in other games at it's native res although i havent done much testing, It seems to be only UT's so i think it's due to their speed.
Can't see the point in buying another 5 ms screen like the OcUK/Digimate 24" mentioned above since your screen is also 5 ms, but with a 2 ms screen you should get less ghosting. Maybe Samsung 226BW/2232BW.
As for whether to return the Hyundai, it's really up to you to decide whether you're happy with it.
