Hello all,
As my other half keeps hogging the TV with Eastenders, Only Way is Essex and such, I'm looking for a monitor primarily for Xbox 360 gaming.
Either 22/23 or 24" will do, as long as it is no taller than 44CM (the space between my unit top and the TV mounted above it), and I am wanting to connect via HDMI. Budget, anywhere between £150-£250.
I've been researching for the past few days and the one I keep coming back to is the Samsung P2450H, but at the end of the day, I really don't know what is the best about that would be suitable for 360 use at the moment, so if anyone is able to recommend some monitors for me to check out and read up on it would be much appreciated.
Samsung P2450H - http://www.overclockers.co.uk/showproduct.php?prodid=MO-124-SA
Ta,
James
Ta,
James
