Monitor help
12 Dec 2002
My new monitor has just turned it's self off and wont turn back on, If I unplug the IEC lead for a bit and then plug it back in the blue LED lights up for a few seconds then turns its self back off and wont go to standby. Is this some form of thermal cut out? I hope so
Thanx for any help
Its a hyundai n91w.
I am using the computer now on a diffrent monitor so the graphics card is fine.
It's weird the monitor was working fine the it just turned its self off and now i cant turn it back on, only if i remove the poewr lead and plug it back in and even then the power is only on for a few seconds then it goes
I had the same problem with my LG 1960, wen't to the service centre and got straight away a new one. there the proint was not available at that moment.
How old is the monitor ??
