Monitor Issue (blurred text)
6 Feb 2011
At your mums
Hi,
I am currently running two ViewSonic VX VX2260WM 22" Widescreen LCD Monitors with a Sapphire HD 7850 2GB GFX.
1 is connected via HDMI and the other via DVI to VGA port on monitor, now the DVI to VGA monitor is fine its the one connect via the HDMI cable that seems to have a slight blur on small text making it unreadable.
I have checked all the settings on the monitors and they are identical, I have even swapped the monitors around and still the same issue so its definately not them.
Are there any other settings I am missing that could be causing this issue?
Thanks in advance.
