Monitor keeps going to sleep while gaming.
30 Apr 2009
Couple of months ago while playing games my pc would freeze and the monitor would have all multicolored dots all over my screen.
Then the problem wasn't as frequent it would crash after few hours only.
Couple of weeks ago ive turned on my pc and went to play TF2 and as soon as i connected to a server and pressed join team the screen would just go blank straight away and the power button would start flashing like its on stand by mode. (Same thing on CoD 4 straight after a connect to server)
My pc is still running and i have to restart it manually by holding down the power button. Ive tried to use restart button but it would just keep restarting for some reason.
Ive tried reinstalling drivers from 185.08 to 185.50 to 185.85 and still same story.
I get this on CoD 4, TF2 and i dont get anything on HL2 single player or GTA SA or HOMM 4.
On HL2 and GTA SA i usually just get a multicoloured dots freeze after a few hours of play and then the screen would go stand by after a few seconds.
Sounds like a possible faulty VGA card, do you have another card to test the system with, as above, is it ok when Not playing games?
Sounds like your graphics card to me. Has your mobo got onboard so you can plug your monitor to that?
I dont have an on board card unfortunately and everything is fine when i'm not playing games.
I've got a GTX 260 coming tomorrow hopefully so i can see whether its my old card.
