I'm looking at a new desk as the one I've currently got is an old Argos one that's already broken once, it's not big enough, and is bowing from the weight of my work ultrawide. I'm looking at buying a dual Vesa desk mount as I have the ultrawide and a secondary 24" (which is my personal monitor) that's currently sat on a cupboard next to me.
If a mount says it holds 2 screens up to 32" - does that mean they'll hold two 32" screens that are 16:9 as opposed to 21:9? my two monitors are:
LG Ultrawide, 30" 21:9 (2560x1080)
BenQ 24" 16:9 (1920x1080)
The second part of this is obviously the new desk will need to be able to support all of that weight in the centre point... What sort of thickness am I looking at? I'm looking at a desk like the Volz Corner Desk (apprehensive of posting a link to show you because rules...)
If I do need to account for the ultrawide being wider, would a mount like this be enough to hold my monitors: https://www.overclockers.co.uk/koli...tand-desk-clamp-pgw-ac-kol-007-mo-000-kk.html it supports up to 36" so should provide ample room.
Thanks for any feedback!
