Monitor not turning on after static shock
27 Sep 2009
There was some cracking noise as i powered on my PC and the monitor turned off and wont turn on. Seems to have been damaged by static. Is this fixable?
Is it completely dead? No power lights or anything? Or just signal? I don't think 'static' would do that... sounds like something more serious.
If no power light either, and you can see no lights inside the monitor, or even any electrical noise, I'd perhaps try the fuse on the plug.
Are you sure the power cord hadn't wiggled loose? These will arc and audibly crackle if not all the way in.
