Monitor questions
11 Sep 2008
Northern Ireland
hey, I've got a syncMaster 226bw, and I got a few questions. Which cable should I use, the DVI cable or the HDMI? Which would give the better video quality?
When I use the DVI cable, in catalyst control centre, it unlocks different settings, so, if I was wanting the best HD experience (im pretty sure my monitor is HD), which cable should I use and what settings should I be using in CCC?
And lastly, can you think of a way to tell if my monitor is using HD? I mean, it looks great, but when Im watching HD DVD's on it, it doesn't look that spectular with real life actors and scenes (computer generated scenes, look wonderful). Is there any "tick this box to unlock HD, moron" button in CCC? :p
Both are digital so image quality is the same,HDMI can carry sound signals too so only difference.
