Monitor recommendation
11 Jul 2004
I am looking for 12 monitor's for our company. Can you suggest anything that meets the requirements below?
21.5-22"
LCD/LED w/DVI
Must be 16:10 ratio with native 1680x1050 resolution. Cannot be 16:9 / HD.
Must be non-TN panel with 178/178 view angles and 16M colours.
Must have matte screen for glare-free viewing.
Must have fully ergo stand with height, tilt, swivel, and pivot.
Ideally will be thin bezel since these will be used in dual setup
Ideally 5ms G2G or better refresh
1000:1 or better contrast.
Thanks
A Dell 2209WA meets these requirements to the letter (the bezel is reasonably thin - but not super-thin like some).
It uses an e-IPS panel, 16:10 1680x1050 res, matte screen and a great stand that does what you need.
Thanks for the replies guys.
Is there any other options besides the Dell (need to give management at least 2 or 3 options).
The NEC 23" IPS EA231WMi is a nice screen. Its a bit bigger than the 2209WA, higher res and a bit more expensive. However, it is 16:9 aspect ratio and not as responsive as the 2209WA. Here is an in-depth review.
The 24" HP ZR24w is another lovely monitor. It is 1920x1200 resolution, 16:10 aspect ratio and very responsive due to the e-IPS panel. Here is an in-depth review.
Thanks for the reply. I'll have a look at those, but the problem is that the native resolution must be 1680x1050 with a 16:10 aspect ratio.
Ok, in that case the 2209WA is the best pick in my opinion, but there are other monitor with S-PVA panels that tick most of the boxes:
- NEC MultiSync P221W (here is a review)
- HP LP2275W (here is a review).
