Monitor / Speaker problem
18 Oct 2002
watchin scrubs.
Hi
I have just plugged in a pair of Logitech S200 2.1 Speakers and get this awful high pitched beeping coming from them when i switch them on.
I have a Samsung SyncMasyer 223BW monitor, now when i unlug this, the noise stops, plug it back in noise returns:confused:
The volume control does not effect the volume of the beep, but the bass control does, it is at its quitest in the middle, loadest at full on or full off Bass.
So obviously one is interfering with the other (ew err)
Any suggestions?
Ive plugged my old ones back in now, but what would it tell you?
If it continued despite being unplugged from the sound jack then its an emmision coming from the monitor. If it ceased then there is some kind of grounding trouble with either the sound card, case or possibly the sound cable.
Thx ill try it.
