i bought a new system all in seperate components, now the components are put together the monitor states no input when i turn it on.
here's the parts i bought:-
ASRock Z87M EXTREME4 Intel Z87 (Socket 1150) DDR3 Micro ATX Motherboard
Intel Core i7-4790 3.60GHz (Haswell) Socket LGA1150 Processor - Retail
Kingston HyperX Beast 8GB (2x4GB) PC3-19200C11 2400MHz Dual Channel Kit (KHX24C11T3K2/8X)
Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD
Aerocool Qs-200 Advance Micro-ATX Case - Black
I used my previous power supply Cooler Master GX 650W aswell as my dvd writer.
i can't understand what the issue is,
i first plugged my monitor in and connected to the machine and when i turn my machine on the motherboard powers up, the fans turn on and the monitor then displays the message no video input and the monitor goes to sleep.
I then tried inserting my old gcard (only a low profile nvidea) which definately works in my other machine, i connected that to the monitor and still the same thing happens,
the power turns on, the fans spin and the same message comes up on screen as before my monitor then goes back to sleep.
Is there compatabuility issues with the components i have bought?
As i built the machine myself OC support states i must get it diagnosed by a specialist elsewhere.
I cannot fathom where the issue lies at all, i even tried using some different RAM which is only 1600MHz thinkin it may need xmp enabling in bios before hand but alas still the same thing happens.
Is it possible the cpu is dead? would my machine still turn on if the cpu was dead?
i am unsure how the machine would behave.
Please help!
Please help!
