Monitor turns on with pc but no signal
21 Apr 2023
wales
The monitor turns on when the pc power button is clicked but no signal is displayed
All power connectors secured
Gpu has been remounted
Ram has been secured
Hdmi is not faulty
All fans spin including gpu
Gpu fan turns off after 20 seconds ish but I think it’s just the mode it’s on
No bios or anything is being displayed
Windows is not installed either
The pc: https://www.overclockers.co.uk/ocuk...3060-powered-by-asus-gaming-pc-fs-1gc-og.html
The cpu cooler covers the ram but in the product pictures it looks like it doesn’t, any cause for concern?
Is there any on screen display from the monitor? Are you certain the correct connection is selected? Sometimes auto select my not be happening.
I’m very certain the correct connection is being selected because Ive tried all the different ports.
Yeah Its in the gpu. I’ve ordered a new display port cable so I’ll see if it’s the hdmi port that’s faulty.
