- 11 Aug 2004
- Notts
I have seen a Medion 22" monitor and the specs are as follows
Does this mean its a PVA panel rather than TN?
I thought that non-TN 22" were not the norm and certainly not as cheap as £150?
- Visible screen diagonal 55.8cm
- Brightness typ. 300cd/m2
- Multilingual on screen display
- Integrated power supply
- Low radiation accordingly to TCO 03
- Viewing angle: horizontal 178°/vertical 178°
- Maximum Resolution 1680 × 1050
- Response Time typ = 5ms
- DVI-D and VGA Interface with HDCP Encryption and Automatic Signal Detection
- Contrast Ratio = 1000:1
- 2 Built-in Speakers
- Dimensions: 397 (H) × 524 (W) × 224mm (D)
does it mention whether viewing angles were recorded with a contrast shift of 5>1 or 10>1?
