I've always gone with a motherboard with a temp sensor pinout that I use to monitor my coolant temp.
I use Argus Monitor to create my fan curves based on the coolant temperature. The Aquacomputer stuff is great but it makes an already expensive bit of nonsense even more expensive.
.+1 aquero and auacomputer
Been using for over 10 years on various watercooled builds, firstly the Aquero 5le and more recently the 6. Just gives so much flexibility on how you can control things that I've not been able to recreate using motherboard control.
For instance, my pump speed is controlled by a virtual temperature sensor which is both my GPU and CPU averaged. So no matter how much heat is being dumped into the loop from which device the pump ramps up appropriately.
My fan speed control works on another virtual sensor which is the delta between my coolant temperature and the fan intake air temp. The larger the delta, the more my fans spin up.
Also really easy to adjust things in windows using aquasuite, whereas the motherboard software isn't so straight forward or only reliable via bios fan control etc.
E-I
Screenshots showing how my fan and pump controls work
And how my temps and other details are monitored and shown on my desktop
And yes, the aquero's aren't cheap, but they last forever...
It's just hidden round the back in the cabling area. The screen isn't required, just the PCB.How have you incorporated it, into modern cases? I always though the Aquaero was more suited to slot into a 5.25" bay slot like in the early 2000 era cases.
While it is a good bit of kit it`s quite expensive for just setting a fan curve, I get what people say about the board manufacturers bios settings, I use smart fan 5 at the moment and it is a bit clonky to say the least but in the absence of 2 pin temp headers on the AS Rock boards then it`s an option I need to look at.It's just hidden round the back in the cabling area. The screen isn't required, just the PCB.
https://www.overclockers.co.uk/aqua-computer-aquaero-6-lt-usb-fan-controller-wc-31j-aq.html
Honestly, on the scale of what I've spent on my loops over the years at just over £100 it's not really that bad. My first aquero 5 was in use for the best part of 8 years and I only upgraded to the 6 as I wanted more PWM headers so I could run seperate curves over different rads if I wanted. I tend to work on the basis that I'm happy to spend out for something that is really good, as long as I get my monies worth, and I really can't complain about that with the Aquero's...While it is a good bit of kit it`s quite expensive for just setting a fan curve, I get what people say about the board manufacturers bios settings, I use smart fan 5 at the moment and it is a bit clonky to say the least but in the absence of 2 pin temp headers on the AS Rock boards then it`s an option I need to look at.
Thats way too complicated for methere are actual formulas you can make to create complex cooling patterns and triggers, it's really cool if not overly complicated for the average user.
I just need something to set a fan curve to in relation to my coolant temps in the absence of a temp header if I get an AS Rock motherboard, the Gigabyte ones are quite well spec`d in relation to fan and temp headers.My b550 rig strix itx has one. I was curious what it was for a while but now I love seeing my water temp lolmI wish ITX boards included one but unfortunately every iteration of ITX board i've had, has never included one.
.Insane that your B550 board has one yet my Asus Z690-i doesn't! Annoying tbh.
I have the Asus B550-I rather than another manufacturer because it has one. Asus have had the T_Sensor on their premium ITX boards for generations. I had a look and it's back on the Z790-I and the B760-I but also not on the B660-I. Seems like just for 660/690 chipset ITX motherboards they did not add one?![]()
