- 6 Jan 2013
- Rollergirl
My build is complete using Monsoon fittings. I'm looking to put a second GPU under water and need 4 of these bad boys...
http://www.overclockers.co.uk/showproduct.php?prodid=WC-117-MO&groupid=962&catid=2531&subcat=2537
Unfortunately, OCUK have been out of stock on them for weeks. I have checked elsewhere (I know, sorry OCUK) but they are either out of stock or £20 a pop.
Could any of you suggest an alternative fitting that won't look out of place with the current Monsoon fittings (see photos in my sig)? Is there a supplier you use that maybe I haven't tried?
I know OCUK frown on links to alternative suppliers, but this product isn't available from OCUK so maybe a mod could clarify if it's OK for folks to suggest a supplier that does?
Thanks in advance...
