Good evening, my water loop decided to p!$$ all over my xfire set up killing the bottom gpu and possibly top where some water got under the top plate. bit of green corrosion like substance where the xfire led lives, bottom card has not got a top plate there's a 50p size of corrosion like crap.
Anyway I found the cuase the glue that holds the collar to the tube had failed on one of the fittings. Seems I somehow got skin oil on the tubing and the glue did not adhere it also seems I missed this one when I reglued all collars as the tube is smooth and i roughed up the collars and tube.
Now I have only one collar to glue and I can't find the uv glue I did find three bottles of liquid cement (used to glue plastic bits in models) in verious viscositys. I don't mind ordering one bottle of glue ocuk have it in stock problem is it will be Monday or Tuesday by the time I get it, I was hoping to get wildlands and play Saturday night.
Would liquid cement be safe to use on pteg? It Dissolves the plastic to make a bond.
