** MONSOON PRO BENDER KITS ARE BACK! **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
A few months ago we get our first and only shipment of Monsoon Pro Bender Kits.
These sold out the day they landed. mental.
Monsoon have stopped selling these kits as they have seen more demand for individual items and have been working to complete orders for that.
We have a lot of bending hardware due in towards the end of the month and I have put them together into a full kit again.
These kits from OcUK are the same price as the original Monsoon Pro Bending Kits were and include all of the same things.
For those interested in hardline tubing, we I have a number of discussion threads open right now:
** MONSOON HARDLINE RANGE UPDATE **
** MONSOON HARDLINE - ACRYLIC TUBING INSTRUCTIONAL GUIDES **
We are expecting our next shipment of Monsoon stock to land around the end of the month. These bundles will be available for pre order until the stock lands and will be available thereafter to keep things easier for you guys.
Monsoon Hardline Pro Bender Kit 3/8 x 1/2 (13mm) - Value Bundle @ £54.95 inc VAT
Only £54.95 inc VAT.
ORDER NOW
Monsoon Hardline Pro Bender Kit 1/2 x 5/8 (16mm) - Value Bundle @ £54.95 inc VAT
ORDER NOW
World Class Tools. World Class Results. Make sure to check out our How-To tutorial videos below for all the information, tips, and tricks you need on using these outstanding tool kits.
Included Tool Kits:
Mandrel Kit: Everything you need to fixture and bend acrylic hard lines.
- Includes mandrels in 45°, 90°, 180°, and 360°.
- Mandrels feature extended support "arms" that hold your tube in position while bending and set the precise angle you want.
- Mandrels feature polished center line channels that help maintain the tubes round shape while bending and allow the mandrels to perform double duty when mounted to your building board-they can be used to bend or as holding fixtures.
- Center line capabilities make loop planning, measuring, and using the fixtures very easy by eliminating all the hassle of inside/outside bend radius and top/bottom positioning.
- Each mandrel has one or more thru-holes that allow you to easily mount it flat to your building board and the included 90 degree brackets allow you to mount the mandrel vertically so you can fixture or bend in two planes simultaneously.
- Machined from solid aluminum and anodized for maximum durability and long service life.
- Tube channels are polished to prevent marring the tube while bending.
- Mandrels are clearly laser marked for bend radius and include hash marks in 1 degree increments.
- Mandrels are also color coded by tube size-Red for 1/2 x 5/8 (16mm) and Blue for 3/8 x 1/2 (13mm) to make grabbing the right size easy for pro modders.
- Includes all screws, brackets, hardware, and hex wrench.
Cutting Kit: Everything you need for clean, precise, square end cuts in acrylic hard lines.
- Includes a machined aluminum miter box for making clean, precise, perfectly square end cuts in acrylic hard lines-the first time, every time.
- Miter box is polished and anodized for maximum durability and long service life.
- Miter box is color coded by tube size-Red for 1/2 x 5/8 (16mm) and Blue for 3/8 x 1/2 (13mm) to make grabbing the right size easy for pro modders.
- Miter box is sized specifically for 1/2 x 5/8 (16mm) tube so the tube stays in place.
- Includes a 6" hand saw with an extra blade and a simple lever operated blade changing system.
- The saw blades have teeth specially designed for making smooth clean cuts in acrylic.
- Includes an inside/outside tube reamer to easily clean and deburr the end of your tube after cutting.
Measuring Kit: Everything you need to take advantage of the built in Center Line capabilities of our fixture and bending mandrels. This measuring kit makes loop planning and measurement right inside your case fast, easy, and most importantly, very precise. No need to worry about inside or outside diameters, top or bottom positions, K Factors, or any of that hassle.
- Precision laser cut from 3mm thick acrylic.
- Dimension markers are silk screened and are in 1mm increments.
- Includes one (1) 300mm rule, one (1) 200mm rule, and four (4) 100mm rules.
- Includes two (2) 45° and two (2) 90° acrylic brackets for planning and measuring complex loop paths.
- Includes all hardware.
Heat Gun Kit: Everything you need to heat your acrylic tube for proper bending and to prevent you from getting burned.
- 1800 W heat gun with 2 heat levels.
- Chrome plated metal diffuser to help focus the hot air where you need it.
- Cotton gloves to protect your hands.
- Solid silicone bending insert to prevent the tube from collapsing while you're bending it.
- Silicone insert is custom molded to the correct ID for your tube-no sanding or struggling to insert or remove it.
Goddamnnnnn! I... wanna give this a shot as everyone makes it out to be really easy!
Just measure, measure and re-measure they said.
Have been toying with the idea of a watercooled setup for a while for a while, but got hampered when I couldn't find blocks for my old MSI 670's so put it on the back burner.
But have had the upgrade itch for a little to long now and some of the logs you see with people using Monsoon Hardline setups, they look fantastic and pushing it to the buy now button to try build something new.
Now my question I guess is which is the better option 13mm or 16mm, or can you do a bundle with boths kits minus the heatgun?
Can you confirm whether the silicone insert is hollow or definitely solid. Seen some kits where people have got the hollow inserts and they are pretty crap tbh.
the parts are due any day now. they are long overdue but you must remember, Monsoon are a small company, getting orders to us takes a long time.
Good to hear :)
I was hovering over the buy button for a bunch of the Monsoon fittings only to get the news that I'm getting kicked out my house :mad:
Pc Build takes another hit:(
