** Monsoon **
right then guys,
I have all of their compression fittings set up on the back end now.
I just need to set up their rotary fittings then the range will be ordered and listed for pre order.
Actually why don't OcUK get some of the Enzotech ones as well?
Their Matte black series looks gorgeous as well ;)
I had a dream the other day that I bought some new fittings i got from ocuk and all the tubing just popped off one day
I woke up in a cold sweat :/
I had a dream similar to that where I woke up having fitted a water loop the night before and the tubing popped off and fried my PC.
I woke up and my PC was off. (I leave it on 24/7)
Almost had a panic attack and scrambled out of bed to survey the damage but quickly realised that my PC didnt have a custom loop in it, and that there had been a power cut in the night. :rolleyes:
Do you guys have an idea when you will actually get the fittings in? Im planning on buying some next payday but its all on pre-order status.
Also what about the reservoir?
Im also looking to buy that as frankly its sweet but no one in the UK sells it. I will likely be buying it in september to finish my loop off but as it stands now ill have to import it from US/Canada.
fittings in, rotary will be here soon. still no word on the reservoirs but i have asked the question today
I was so on changing to these when this thread started. Now after seeing primochills rigid tubing, i am getting cold feet about ordering, since i will just switch to try acrylic out soon after anyway.
Hurry up monsoon and make some sweet fittings for acrylic tubing, so i can have both!
Hi Guys
Updates:
Monsoon is nearly all live now, we are expecting another order very soon.
Coming soon we have Chain Gun Fittings
and Monsoon reservoirs :D
more info as it happens.
