more cpu or ram speed?
14 Feb 2011
hia i currently have my q9550 @ 4ghz and my ddr2 corsair 6gb ram at 942mhz. was wondering if it would be better to sacrifice cpu speed partially for more ram speed or not? cpu would go down to 3.94 and ram would go up to 1115 mhz.
ta x
You probably won't notice any performance difference if you increase the ram the speed, i would be inclined to keep as is.
hia ok all take your advice ta.
any advice on getting my cpu up towards 4.2? got a asus p5q deluxe and i find it hard to get it stable. ta
