More diving equipment advice...
Luke284 said:
i do agree that DIN is technically a better system, however i have A-clamp as i dive in areas where this is more common. if i dived mainly in the UK or any other DIN mainstream country then i would get my regs converted to DIN.
Depending on your reg this is a simple spanner job. You unscrew the DIN barrel and replace it with the A clamp version.
cleanbluesky - it may be useful to let us know where, how often you dive etc. and where you see your diving going in the future.
He's undergoing initial training with a BSAC club
VeNT said:
I realy should get back into scuba, did a padi advanced open water diver course back when I was at school (wanted to do BSAC but non in area at time).
bit cold down here atm for it, maybe I'll have to move to austrailia first!
You wuss, you live in cornwall which has got some of the warmest waters in the UK. Grow a pair and go diving. If I can do hour long dives in a flooded dry suit in 4ºC water then you can go diving in a balmy 20ºC wearing a wet or dry suit.
Sleepy said:
You wuss, you live in cornwall which has got some of the warmest waters in the UK. Grow a pair and go diving. If I can do hour long dives in a flooded dry suit in 4º water then you can go diving in a balmy 20ºC wearing a wet or dry suit.
20ºc you think?
when where you last down here?
spirit said:
20oC water temp??? what depth was that at, id have thought it was much colder than that..
The thermoclines fairly deep in summer.
VeNT said:
yeah it is, he's got one of those water heaters strapped to himself
Nope just a suit bottle filled with argon, for when it really gets cold.
Oh I also get 20C water off East Kent to in summer
