(More) P5W DH Questions!
1 Nov 2004
Southampton
OK, three questions.
My Spec:
Asus P5W DH Deluxe
Core 2 Duo E6600
2x 1Gb Geil PC2-6400 (4-4-4-12)
X1900XT
530W Hiper Modular
1. My mobo temp as displayed by Speedfan and PC Probe is around 65 degrees! My computer is totally stable at this temperature, but a temp that high cannot be good. I am running at 3064 Mhz with an FSB of 340 right now, but have had the computer higher (around 3.3 Ghz stable)- I am not sure what the temps were at those speeds! Do I need more airflow around the northbridge/southbridge? For reference my CPU is around 40 degrees.
2. Which sensors do the three readings in speedfan refer to? Sensor 1 is obviously the mobo, sensor 2 the cpu, but I'm unsure of what sensor 3 refers to - but its reading 125 degrees!
3. My computer has a strange habit- when power saving comes into operation and the monitor goes into standby, it is often difficult (and sometimes impossible) to get back to where I was before. The monitor will appear to come out of standby (the light will change from orange to green) but the screen remains black! By frantically moving the mouse and randomly hitting keys sometimes the screen will come back to life, but other times- no matter what I do it wont. I am sure this is due to the mobo and my monitor is fine (Dell 2001 FP). Any ideas?
Thanks in advance, Simon
simonmc7 said:
*SNIP* 2. Which sensors do the three readings in speedfan refer to? Sensor 1 is obviously the mobo, sensor 2 the cpu, but I'm unsure of what sensor 3 refers to - but its reading 125 degrees! *SNIP*
The third tempurature is the Voltage regulater, left of the CPU. Where the Heatsink first starts off.
Correct me if I'm wrong.
Its a dodgy probe. Mines currently at -4C and if i alter the speed03 fan to 100% it then shows 125C :D at 38% it shows as -4C its deffinatly dodgy and should be ignored! As i dont even have a fan on mine....
Thanks for the replies guys- I think I will try the reseating of the heatsinks and see how it goes. It just seems strange my temps are so much higher than everyone elses.
Any further input is appreciated!
Simon
Take the "Asus" covers off both heatsinks, and put a small fan on the SB.
The NB barely gets warm, but the SB gets quite hot and that's the one reporting high temps. Mine was at 45~50c until I added a fan on the SB, now it's at 30~35 load :)
There's another thread here somewhere about adding fans to the P5W chipset heatsinks, with pics etc.
Here:
http://forums.overclockers.co.uk/showthread.php?t=17618648
I have the same setup (mobo, ram, cpu).
Can one of you post your BIOS settings? Asus have all these auto settings and other options that I don't know what they do.
Am having trouble OCing my E6600 very far.
