More problems....now its the sound
  • Thread starter Thread starter sid
  • Start date Start date
sid
sid
9 Feb 2003
London
I can't get stereo sound to work on my setup
IP-35 Pro - using onboard sound
Using the green jack and 3.5mm to 2 phono cable connected to a stereo setup.
Cable is fine, speakers are fine, I tested on another pc.
Im using Vista x64 with R.1.98 drivers (newest ones)
Basically Right hand speaker sound are not coming out
Any ideas?? Its a driver problem obviously
Probably sounds silly, but it hasn't just shifted all the sound to one speaker by any chance? Should be able to check the sound options to get the levels.
Yup volume is levelled between two channels equally.
I have no elimated everything but that port itself. It appears to have broken somehow. Weird
If i plug them into black slot and enable quadraphonic, both speakers work. I've managed to get stereo working by enabling "speaker Fill" option to double channels
ridiculous, i have had nothing but problems with this motherboard.
Not sure whether to get new speakers or a sound card now
