I would also strongly recommend asking to speak to the site manager and asking if he can put you in touch with the spark. If your TW site are anything like mine they'll be wanting £50 a piece for halogen spotlights.
Speak to the spark, behind the sales team, give him plans for your lighting so he can do a first fix. Supply the fittings & units (I'd recommend LED - the initial outlay is more but will still be cheaper than what you were prepared to pay for halogen and will give you significantly lower bills) yourself and have him come and fit them once you've completed and moved in.
That's what I did and I saved a fortune (under £20 per light fitted with a decent LED bulb), down lights, power & light to garage, shaver sockets, TV points etc.
Of course if your site aren't as lax as mine then there's not much you can do.
Sounds interesting indeed - they charge £70 per spotlight in the development I'm on, everything is more expensive down south unfortunately.
I have an allowance I can spend on things before I have to cover extra costs myself, a good chunk of that would be going on spot lighting.
You can put LED bulbs into the spotlight slots though right? or does it need different sockets? I would need a lot of spotlights to be honest so LED may be the way to go as I would save a lot on electric bills.
I was reading the thread on the LED lights and they sound great for cheaper power usage, and also how long they last, but a lot of people said they also give a "cooler" temperature light, halogens give off a much warmer (more expensive) light.
Just follow the normal MSE guide for home insurance (basically using comparison sites plus a couple of extras). However be warned that many insurers won't let you get a quote for a policy start date more than 30 days in the future (some 90 days) so you could be jumping the gun a bit.
[This reminds me I need to get some quotes!]
In terms of getting flogged expensive insurance the key thing to watch out for is more likely to be life/disability/income protection insurance. Especially when going via a broker, they will probably try and push you down that road to try and get some commission. Home insurance is mandatory, you definitely need that, but personal insurance is entirely optional and if you do decide you want it again make sure you shop around.
Sounds like it will be easier to go with the Mortgage peoples house insurance first off, and switch after a year or so then. Does this include contents insurance or is that a totally separate thing altogether?
Not sure what to think about other types of insurance to be honest, I'd be the sole dependent on the mortgage so I would perhaps feel safer with some cover in case I couldn't work for any reason and still needed to pay the mortgage payments. Work would probably cover me for a little bit in this event but not forever.
