- 2 Feb 2010
- Crowmarsh
you just need to transfer £1500 to 40456523 21-06-87 and you are done
Nice try
House is worth about 140k and we want to buy something for about 200k.
Obviously we don't know how much your house is worth at present.
However. if you were accepted on you own and had a mortgage of 100K, then applying for a joint mortgage with your girlfriends wage also considered meaning a higher mortgage available. Then add in the rental income of the new property increases it even further. You could also put the existing house up as equity against the 2nd mortgage.
The aim is to have as small a mortgage as possible. Girlfriend has some money saved up.
IMO you would be making a mistake selling it.
£200K with her deposit and both your wages and the rental income would be easy to get anyone sign off on.
I thought most lenders don't consider rental income when evaluating mortgage affordability?
If he doesn't sell the old house then he'll effectively be paying a mortgage on the value. He'll need to borrow £140k more against the new house than if he'd sold the old house. That's going to be a much higher LTV and therefor have higher interest rates.
He needs to balance up how much he'd get from the rental income (after paying tax on it and maintenance costs, etc) against having a cheaper mortgage and which would give him a lower overall cost. It's not as straight forward as saying "it's a mistake to sell it". It may well work out better off keeping it and renting it, but without knowing all the details, it's impossible to tell.
Yep, it may well be possible for him to get a mortgage on the new house but my point is that it may not be the best option.
Let's assume his gf has 10k deposit.
He sells his old house and puts the 140k towards the new house.
The 200K house with 50k mortgage over 20 years at 1% gives £230 per month*
If he doesnt sell his house, and they only have the 10k deposit from his gf:
the 200k house with 190k mortgage at 2.49% gives £1006 per month*
So does the rental income (-tax, -maintenance of old house, -months when house is not rented) make up the difference and, considering the total value of assets at the end, is that the most effective way to invest his money?
*used best rates I could see for the LTV values.
So £408 a month more means he has 2 properties instead of the 1 with value of £340K vs £200K.
That's possible. It's also possible that it doesn't increase at all or drops in value.assuming house prices don't increase at all. they could increase 2% every year easily
"ease" is not a word I would use to describe investing in rental property.there is nothing he could invest in with as much ease
If the sums work it's worth doing, but yeh, ease is definitely not a word I would use unless you go fully managed which then eats into profits quite a bit.
Lots of interesting thoughts, cheers guys
At the moment I'm just concentrating on getting the mortgage right down.
One of my big problems at the moment is job stability. Chances are I could be out of work by the end of the year
But if that happens I'll be walking away with a huge payout having been there 27 years.
If your expecting a big pay out for redundancy then don't let it worry you to much. Statuary redundancy pay is capped at £14670 (£15k in N.I) and obviously depending on the company they might pay a good bit more than that. So worst case scenario the redundancy could keep you going 6-12months (depending on your current lifestyle/salary) which would give you plenty of time to get back into employment and then any remaining amount could be used as an overpayment to reduce mortgage repayments or keep it aside for "work" as and when required at both properties
