Simon, what LTV out of interest?
85%
The fixed term (or the introductory rate of a tracker) lasts for a set number of years. Then you fall back onto the standard variable rate of the lender. It is important but generally most people will remortgage once their introductory rate has lapsed. The key is in making sure there are no or very little redemption charges (often called ERC or early repayment charge). This way you can either stick with the SVR or remortgage, it depends upon what the markets are doing at the time.
Im looking to fix for 5 years. So it will just be a case of getting a new deal as the product expires
I used a broker who charged no fee, got a lower fee mortgage then I could directly. A lot of the mortgages were under £1000 fee too, some were even no fee so I can't understand the assumptions above.
His only payment was commision from the lender, which was clear in the contract and was £600.
Conveyancing is what your solicitor does. The estate agent and/or broker don't do this.
I chose not to use a broker, wish I had now.
I went with HSBC - they've just changed the way they do mortgages as of 1st Jan so that you have to use one of their selected conveyancers and let me tell you, they are rubbish! I applied for my mortgage in January and am only just exchanging contract now - in April!
Brokers take the stress away and can advise you on things you wouldn't normally expect. They generally don't show you the HSBC's / First Direct etc. as they don't pay them commission, but in hindsight I would have happily paid a slightly higher rate than go through the pains of an HSBC mortgage.
