Most efficient decoder for H264?
18 Oct 2002
North Wales
Hi Just wondering which is the most efficient codec for H264, i.e. low CPU usage.
I'm currently using MPC-HC with FFDShow, tried the DXVA option but it had problems issues whereby it wouldn't resume from pause and seek didn't work.
This is under W7 btw...
Any better to use?
CoreAVC is the most efficient CPU based decoder, plus and supports CUDA (hardware like DXVA), but it's not free.
32-bit MPC-HC is by far the best choice though, free or otherwise. You don't need FFDShow, or any other piece of software.
You probably have the EVR settings incorrect and/or a conflicting codec installed too.
Post screenshots of the EVR output settings page?
DXVA via internal decoding should load instantly, much faster in MPC than any external decoder like ffdshow/divx/coreavc.
Yeah I've used CoreAVC before, but don't really fancy paying for it to be honest.
I'll do that later when I'm home, cheers.
I did notice that using WMP12 resulted in <20% CPU usage, which was at least as good if not better than DXVA in MPC-HC.
This was with a 720P mkv...
DXVA should yield <5% usage when working correctly.
Download Splash Player (Lite) and make sure hardware decoding is enabled. Monitor your CPU usage to get a rough idea of what it should be like. On my quad, it averages out at 1-2%, with the jump when fullscreening etc.
I use the PowerDVD H.264 decoder because it seems to be the only codec that can play 1080p on the following hardware:
1.8Ghz C2D (the original E6300).
Geforce 7600GS
Getting a Q6600 soon though so should be able to use standard multi-threaded decoding offered by FFmpeg that's built-in to MPC-HC.
To be honest I prefer VLC as it just works with all files but you really need a powerful CPU to make 1080p work. Can't wait for them to add multi-threading.
What's the usage like with the MS decoder? It should be pretty low. You can play mkv and avi in media center if you register the splitters from the MPC-HC standalone filters pack.
Minimal codecs is how I roll these days. ffdshow is only used to bitstream HD audio to the amp.
Do you mean you can use the built in x264 codec of W7 in WMC? More details please :D
You said to post screenshots of the EVR settings page, I'm asking where the EVR settings are :D
Although I'll take your settings if you're offering, this Asus is pretty similar in spec to the 13z... :)
