I could be wrong, but I think that was the brand that failed on me (bearing seizures) in a pair of CoolerMaster PSUs, both in under two years of normal usage. I replaced both with Arctic Cooling F12 fans at around a fiver a pop. They've both been much quieter and 100% reliable ever since.Is the sanyo denki the same fan as some PSUs use ?
For proper high flow, you need to be looking at delta, san-ace, panaflo, nidec and sanyo denki.
A prime example is the Delta PFB1212UHE, which flows 252cfm which is 2.5x more than both the noctua or EK above. Expect noise a plenty though and an eye watering cost per fan.
For a demist fan, most manufacturers use a centrifugal fan rather than axial.
Delta fans are pretty powerful
The 9G1212H101 was the godly San Ace model number. Okay this review is from 2012 but back then it was the most powerful (and best cooling) fan on the market.
it may have been superseded by now
http://www.vortez.net/articles_pages/120mm_and_140mm_fan_comparison,11.html
Im guessing a fanguard is pretty essential on one of those, i imagine chunks of skin will start disappearing if ya get too close while messing with summat in your case.
