Motherboard advice
25 Aug 2012
While we are waiting for all the graphics cards to be release I started to plan my upgrade (new PC) as my current one is getting on a bit and is now beginning struggling with keeping up with work loads.
I run a couple of VMs off my computer while working - I also use it for gaming so was planning on getting an 9900x with 64Gb+ of Ram but I really have no idea when it comes to motherboards
I currently have 2 m.2 drives and 4 SSD's that I will be looking to move over but I would like the capacity to add more if needed.
Wouldn't a 9950x3D make more sense if you use it for gaming and productivity?
I can recommend the x870 tomahawk, am running 3 NVME drives with no compromise to the drive speeds or GPU PCIe lanes. Plus it doesn't break the bank.
It will obviously support SATA as well.
