Motherboard caught fire....
1 Jun 2008
Hello, i recently purchased components for my new build. I have built a few computers in my day so i like to think i know what im doing.
So i put everything together inside my case and plug it in and press power....nothing, so after spending a lot of time narrowing down what it could be (trying other PSU's, Other cases etc etc) to no avail, i finally press the power button whilst the PSU isnt plugged into the CPU power on the motherboard and voila there is suddenly power to all the fans and motherboard, but then something shorted and popped and the motherboard caught fire.
Wondering if anyone has any ideas on what it could be , only thing i am able to come up with is that its a faulty motherboard but i'd like to know if i am incorrect.
Thank-you in advance for any replies -
Here are my components;
definitely the mobo sounds like there was a dodgy capacitor and it wasn't routing the power properly and then it popped and that explained your fire.
usually these things happen with MSI boards, never heard of it happening to an asus before, guess theres a first for everything
extremley common problem with asus boards, do some googling and you will find that asus was caught out using cheapo tiwaneese capacitors and not proper decent quality japaneese ones. many articles about this over the web. never bought asus mobo since.
Sorry to hear your motherboard has failed. :(
Sarcastically speaking though Asus again!! lol :rolleyes:
Just get it replaced if it's within the 1st 30 days they will replace it straight away I think.
Did you know Asrock is a subsidiary of Asus?
.Did you know Asrock is a subsidiary of Asus?
yep, hence why my dual-sata2 board failed on me. not much option left in the s939 sector with the asrock matx board being the only one available now.
will avoid asus/asrock from now on if possible. plenty of other manufacturers out there to choose from like dfi, gigabyte, evga, etc etc.
that's the second time I've read about someone's motherboard shooting up.
you can do what you did safely, I've done it with my asus and it's a fine thing to do.
Did you manage to take any pictures of the crispy board before it went back? Wouldn't mind seeing the damage?
oh also, I recall that the guy previous that I read had other components affected by the fire and the company covered the cost to damage there also. Did anything else get caught?
would be interesting to see a pic of the damage, never seen a blown up mobo before, might be able to tell where the damage started from on the board.
Cool, that's the same motherboard I have, although the image does look slightly different somehow. If you're installing W7RC do you might in letting me know if your drivers install, I couldn't get mine to work :)
cheers
I thought this only affected late 90's machines but it appears not... Was it Teapo caps by any chance?
Need a little help guys, as i am getting very frustrated.
After i got this replacement i also purchased a Saphire HD4890 and when i turn the machine on, all the fans power up and power is supplied to the card. However, there is no signal being sent to the monitor and i notice that 3 red lights stay constantly lit on the card which suggests that my machine isnt posting, i am getting no beeps and the motherboards lcd display suggest no problems.
I tried a friends card in my machine to check that it wasnt my PSU not being powerful enough to power the quad core and graphics card but i had no joy with that, and after he put his card back into his machine it wont work, when it worked perfectly fine before.
Any ideas what the hell is going on? I've never had this many, or this big of a problem with any machines ive built in the past. I'm about ready to throw everything away and never use a pc again !!!
Thanks for any help you can give.
