- 28 Jan 2005
- Lymington
Hi Guys,
Having a problem with my new HTPC/future gaming build. Specs are:
Silverstone GD07
Gigabyte Z97X-SLI
i7 4770k
16GB TeamGroup Vulcan ORANGE 2400MHz
SuperFlower Golden Green HX 650W "80 Plus Gold" Power Supply
120GB Samsung EVO SSD
4TB, 3TB & 2TB SATA
Here is an snippit of the user manual to help the information below.
The following was performed with nothing but the bare essentials connected.
I cannot seem to get the machine to POST if any RAM is in slots DDR3_2 & DDR3_4 (Channel A). It doesn't matter what stick(s), it won't POST. DDR3_1 and DDR3_3 (Channel B) are fine and the machine boots with 8GB. I've tested all the sticks in slots 1 & 3 and the machine boots perfectly each time. However nothing will POST if any of the stick(s) occupy slots 2 & 4. This means I can use 8GB max and the other 8GB is effectively unusable. Does this point towards a motherboard problem? Everything is brand new but the i7 was bought off the MM and the previous owner had it at 4.4GHz so I'm pretty sure the CPU is okay.
I also can't seem to get any output from HDMI ( have not checked settings in BIOS but assumed it would just work!?) but VGA is fine.....
I'm about to pull the trigger on a replacement one as I need this working ASAP. Do you guys agree it's almost certainly a motherboard issue?
Thanks for the help
Silverstone GD07
Gigabyte Z97X-SLI
i7 4770k
4TB, 3TB & 2TB SATA
Thanks for the help
