- 5 Dec 2010
- Solihull
Hi chaps/chapesses
Could I please as your advice on a problem I'm having?
I'm building a system for my Missus' family which includes:
Intel Core i3 2120 3.3GHz Socket 1155
Corsair 4GB (2x2GB) DDR3 1333MHz
Cooler master Elite 330 Case With Coolermaster eXtreme Power 500W PSU
Seagate 500GB 3.5" SATA-III
MSI H61MA-E35 (B3) Intel H61 Socket 1155
Initially It turned on and fans started to spin then turned off and repeated this process until the PSU was switched off.
Huuuge schoolboy error though that I didn't put the stand-offs in initially and had it screwed partially to the case. So I figure I've probably fried it?
At the moment I've got the mobo outside the case on cardboard with the ram
HD, Keyboard, mouse and connected to the power supply, it it doesn't start up at all now. It does power the usb though, if I set the jumper to power while not on. I've canged the other components likwe the ram and PSU for known working ones. I can't test the CPU though as I have an AMD system.
The motherboard is a bit bizarre though, There aren't any lights, and can't hear post beeps because there doesn't seen to be anywhere I can plug in the onboard speaker.
Any suggestions? Should it turn on without a monitor or should I plug one in?
Thanks
Thanks
