Motherboard heatsinks for NVMEs
16 Apr 2004
Shropshire
Please accept my apologies if the following question is stupid.
I'm in the process of building my next rig using a mini ITX motherboard (ROG Strix B650E-I)
Like a lot of motherboards, it has a couple of M.2 slots - One is on the front underneath a fairly chunky heatsink and thermal pad and the other is on the rear. Albeit the one on the rear has no such heatsink.
So my naive/daft question is this - The presence of the heatsink/thermal pad on the front of the board suggests that NVMEs get hot and require cooling. If that assumption is correct then is there any risk of using a second NVME on the back of the board when there's no such cooling in place?
Again, I'm sorry if it's a silly question. We all have to learn from somewhere.
Nvme m2 drives do not require cooling they just help to lower temperatures as they can run hot if you moving a lot of data for long periods of time .
High temps can lower performance so you could add one to the rear if you prefer but aftermarket coolers can invalidate warranty.
I've used the nvme slot on the rear of an itx mobo before. Would not recommend for constant SSD use. The ssd will get up to 65c and throttle during heavy I/o operation.
Mine at the time was the WD black sn750 pcie3. No heatsink. A thin heatsink may help but Ive never tested it
Cheers both.
I intend to use my main 2TB NVME on the front of the board under the heatsink but based on what you're saying I should be able to put my spare 512GB NVME to use on the rear albeit it will only be used sporadically for some extra storage. I assume that would be ok?
I've run pcie 4 NVME without any heat sink no problems. A lot of it depends if the case has good cooling. Pcie 5 is inadvisable though without a heatsink as they run way hotter
