8 led's, 4 in series, and then another 4 in series, both sets of 4 connected in parallel. that should be 12v per series, which should equal 3v per led...
Been nearly 10 years since i leanrt that though, so don't quote me on it
I'm not 100% on this, as like i say, it was a fair few years ago when i was at school.. this is all from memory. you may need to connect them all in series and have resistors soldered on in some places, there are a multitude of different ways to connect the LED's up.
Enjoy
EDIT: it's wrong, and the wires would go into a 12v and a ground on the molex (yellow and black respectively...) - This only applies if you are using 4 led's in series though...
EDIT2: actually, i'm sure i'm right... i may just try this at the weekend to prove to myself it works....
yeah you need to make sure the soldering ends are covered
i have an idea for you use a UV perspex sheet and wiring up some UV leds into it so the UV sheet glows.
just make it shorter than the board and place it under the board if there is space for it. it should
look sweet if its done right
