Motherboard Problem
7 Jun 2011
Terkland
Hi, we've connected the power switches, restart etc... accordingly as the manual guides on the motherboard but It wont start when we press the button on the case, it works if I do it with a screw driver, any help?
Sounds like a dodgy front panel switch. Swap the front panel power leads for the reset leads and try turning the system on using the reset switch. If it works then you know its the front power on/off switch or lead.
Yup, thanks it was infact due to the dodgy front panel, I can now turn on my computer by using the reset button, once again thanks :)
