- 17 Jul 2011
- East Midlands
Peculiar problem.
On Sunday (and it’s happened just once before), I start up my computer and receive ‘no signal output’ on the monitor. However, on Sunday, I just heard the hard drive (Samsung spin-point f3, it’s quite noisy when it starts up, unmistakable, about a month old), fans come on, the two case lights come on, one for power, other for HDD, and they stay on permanently (HDD usually flickers).
Now, nothing has been moved cables wise, and this time it didn’t come on after a few tries, so I unscrewed the graphics card cable (Nvidia 8800 GTS 320mb), screwed them back in, tried again – nothing. Eventually, I just walked away tried fifteen minutes later and it worked.
Yet when booting in, the time/date was wrong, and it was 2006.
I was beginning to think CMOS battery problems? But no signal output felt a bit extreme.
I turn my computer off rarely, so today, it’s turned off for an hour. I come back to turn it on, and lights come on, hard drive spins, but ‘no signal out put’ is on the monitor.
I turn it off, try again, and this time the power button flashes and stops when you release, if you hold it in, the HDD and power light flash together, and you can here a ‘tick, tick, tick’ like the system is trying to turn over, hold it in enough, and it starts (but still, no signal output on the monitor).
After letting it rest, pressing the power button brought on the HDD/fans again and reverted to the initial problem, and then back to the flashing lights, excessively long hold in, and the tick, and in some extremes, just no light at all.
The system once it was up and running (except for the time issue) ran flawlessly, no slow downs, I was even playing ‘Mafia 2’ this morning.
My expertise is more casual, I know how to exchange/swap out components, devices, but diagnosing definitely isn’t my forte.
Is there a way to tell a faulty motherboard from a failing PSU?
