Motherboard screws
13 Dec 2005
Just got a fright reading another thread saying that using the wrong screws can fry your board ? is that true ? Half of the screws im using to mount my motherboard arent the ones that came with the case and havent got washers to seperate the metal on the screw and motherboard mounting holes. Do i run the risk of frying my board ?! :confused: Ive been running it like this for afew weeks now.
Ah yes, thanks. Ive just this minute checked, the screw heads do not go outside of the circular metal plate around each hole. * wipes sweat of forehead *
p.s thanks for the quick reply, didnt think anyone else stayed up this late :)
