Motherboard too low
25 Oct 2009
Northampton
Hi Folks,
Hi Guys, just received my new Bitfenix Survivor case. I needed an ATX case with a handle.
Installed the motherboard with the provided stand-offs and it sits too low in the case for my expansion cards to slot into the PCI-e lanes.
Does anyone know of a work around, like slightly taller stand offs or should I send the case back?
That doesnt sound right, the standoffs supplied with the case should be the right height to get the motherboard the correct distance of the back.
Did the I/O shield plate and board match up without drama?
That is the weird bit, the IO shield slots in fine. 3 of the standoffs were already installed as well.
It needs to be a good 3-4mm higher.
Are you sure you fitting the cards correctly?
Sounds daft but you never know?
Also try losening the screws that hold the motherboard and moving the board a bit away from the expansion slots
I was thinking a similar thing.
The "tab" end of the backplate sometimes catches on the case or motherboard and prevents the card from being pushed in any further.
haha, yep I'm sure. the top of the card (right angle) is flush against the case.
I've taken the mounting screws out, checked their heights, put them back in, as loosely as possible without causing issues with the screws, used the minimum number of screws to secure the board to the case, again nice and loose.
the board seems to slope off though, the front of the cards are more "in" than the rear.
But not enough to function.
It would be nice to show us some pictures, it's unbelievable that some motherboard, graphic card or case is not standarized - it would mean whole portion of bad items flooded the world ;-)
I used a x1 because the graphics card blocked too much light.
