Motherboards with PCI-X slots
5 Jun 2006
Singapore
hey guys,
anyone knows of non-server class motherboards with PCI-X slots?
I can only find Asus P5WDG2-WS for Intel and Asus M2N32 WS which have PCI-X slots.
are there any others?
thanks
can i just ask why you would want a non-server class with pci-x? sounds abit rude, but just out of interest.
Hmm.. server class stuffs are too high end for me. but i would like to utilise my SCSI hdds at the same time and not limited to using PCI-X scsi controllers on PCI slots
i do have a Pentium M 755, but i've already paired it with an AOPen i915Ga-HFS.
anyway, i'm looking for a mobo for my main rig which will most likely be an E6600. So i think my best bet would be the Asus P5WDG2-WS.
naro said:
hey guys,
thanks
I have the P5WDG2 WS Pro, can only say that I am very pleased with it, very easy to work with. :)
aa yes. that makes sence. problem is, will you not be cutting features which you would get from a normal board? if you get me? the question is, how much of a decrease in promance is going from pci -x to pci?
PCI is only 32bit at 33Mhz = 133Mb/s shared among all the PCI slots.
PCI-X is at least 64bit at a min of 33Mhz and up to 133Mhz. Hence a bandwidth of 266Mb/s to 1064Mb/s depending on how many slots of PCI-X shared in that pipeline.
thats quite a lot of bandwidth different. And adding a rotational speed of 15k rpm, i think its going to be very much performance difference.
