Motion Sickness - what helps?
25 Mar 2006
Thornbury
I get motion sickness really easily in games and have done for years, i dont play often but i started cod4 today and after 15 min i was dizzy and i am still a bit woosey many hours later.
has anyone found a way of reducing the effects of motion sickness and does and travel sickness pills work ?
just need more practice. I suffered similiar problems when I started playing 3d game,Quake 3 and Half life. But after many hours of practice, I no longer suffer motion sickness
Practise makes no difference, i get motion sickness in lots of games, theres nothing that can be done about it, short of taking a sea leg pill before you play.
Do you get motion sickness with anything else?
Probably sounds a bit silly, but maybe drink a lot of water before/while playing?
what size tv you using? do you get it on pc games? do you get it while in a car/boat? do you get it if start a fresh fps game, put sensitivity on high and spin in the same direction for a period of time?
often something with strong taste helps.. maybe lick salt ^^ or chew on lemon.
Sounds like tequila shots time...
More seriously as you say give travel sickeness tablets a try or get a travel sickness nausea band (they do work ~ my ex had awful travel sickness). Have a look at travel sickness sites and see what they recommend.
