- 20 Aug 2007
- Solihull
Hi guys!
I've been riding a few months on my CBT and I purchased a brand new lexmoto xtrs 125 on finance (I'm skint!
It's got about 1800Km on the clock and is due for it's 2000Km very soon obviously, in the last week or so I've had a few issues, I've noticed it hasn't been happy to start with the ignition button, as in I put a bit of choke on, rev slightly and hold the button for a few seconds (which normally fires it up straight away).
Recently when it try this (with choke in every position) it turns over for a few seconds then I release starter to make sure I don't burn it out, sometimes it also makes this hollow clunk sound when I release the start button.
If I keep trying this for a few minutes (leaving 30 sec gaps to not flood/burn out motor) it will finally start (very grudgingly). It goes pretty much first time if I give it a decent kick start with the choke on though, is this a problem with the electrics?
Also this morning I started it with kick and let it idle for a good 5 minutes, revving it occasionally to warm it up a bit more. When the engine was nice and warm I saddled up and rode off - after about 1 minute I come to traffic lights and come to a stop, as soon as my revs settle back to the resting 1800-2000rpm it suddenly starts to splutter and the engine just cuts out (as if I just let the clutch snap off and stalled it), I try to give it a few quick starts with starter button but nothing happens, so i was forced to kick start it before the lights turned again. Luckily it went first time with kick start again!
Does anyone know what could be causing this issue? I'm pretty new to bikes but have a decent understanding of how my engine works (I plan to get it looked at when it goes in for 2k km service, but this is just for my own knowledge!)
Can anyone advise as to what could be going wrong?
Notes
Thanks!
Jamie
)It's got about 1800Km on the clock and is due for it's 2000Km very soon obviously, in the last week or so I've had a few issues, I've noticed it hasn't been happy to start with the ignition button, as in I put a bit of choke on, rev slightly and hold the button for a few seconds (which normally fires it up straight away).
Notes
- I'm using Shell Vpower Nitro + fuel, almost full tank at the moment
- I normally ride it quite hard and it runs nice and smooth and zippy for a small bike
- If it's been running about 30 minutes and I turn ignition off, it will start perfect on starter button within a few moments after shutting off
- Bike is kept in a garage at night and is always kept warm and clean (where possible)
Thanks!
Jamie
