Caporegime
yh the choke is just for cold starting,once bikes warmed up 2 to 3 minutes turn off the choke,or it'll cough n splutter n stall
Could be that the valve clearances have closed up and it's losing compression. A good swing on the kickstart will spin the engine over more quickly than the relatively puny starter motors on these things, which would give a better chance of starting.
Yeah its definitely a thing, usually caused by seized or sticking caliper pistons, but the discs can be straightened though so don't bother getting a whole new set.
Can you not fit them yourself, or have a mate/family member who could? if they are charing £40 to fit a disk thats a joke lol.
And no probably not, the place I used was £50 to straighten a set.
but will cut if jerk the throttle back whilst it's idling
This is normal on bikes with carbs. You should wind it back gradually not jerk, is it OK then?
