We have tried dealing with this issue for years, but its reared its head again this year.
I'm starting to think we should get a professional out to deal with the problem, but wanted to check if there's anything obvious that should be dealt with.
It is our master bedroom, doesn't adjoin the bathroom, and the rest of the house is mould free.
Things we have tried:
Cleaned the walls with anti mould stuff, which works initially but it returns.
Insulated the loft and ensured there is air flow at the eaves.
One of those moisture catchers, which haven't done much long term as you will see in the photos.
Here you see the outside of the bedroom, there seems to be something in the wall rusting, which alarms me a bit - but can this actually be the cause our problems?
https://photos.app.goo.gl/q7PpDB6hm4cbOAx03
Here is a closer photo of the rust in the wall:
https://photos.app.goo.gl/wZqJ9k6upRUsLlPS2
I also note what looks like a crack in my fascia board, unsure if this will make any difference?
https://photos.app.goo.gl/mLNR7Z9tXgKLpck52
And now for the internals:
I had to strip this wall of the wallpaper (it was infested with mould last year). This is the wall adjoining our neighbours to the left. You can see the ceiling has mould remaining from before the wallpaper was stripped.
https://photos.app.goo.gl/MRsuNHW15gTtkcgL2
Over the period of a year where I have left the wallpaper off for the wall to breathe, we now also have patches like this, where the mist coat of paint is flaking and bubbling away:
https://photos.app.goo.gl/WFuGEmpyhzjyfZ552
These blinds will be binned, but just to show the extent of the problems:
https://photos.app.goo.gl/9Fn55OBloEAOoYzP2
This is the built in wardrobe, which directly aligns with the rust outside:
https://photos.app.goo.gl/UbaHF2yxnTXReE6g2
We are due to redecorate this room, clearly as I've had to rip the paper off the wall - but I don't see the point if it's all going to continue to be an issue. I will obviously scrape off all of the loose, bubbling paint.
Frustrating as the whole house doesn't have one issue other than this room, we keep the windows ajar wherever possible overnight. I've ordered a humidity monitor to check the actual levels within the room, but it does not feel any different to any other room.
Any help greatly received.
