Fix a strip of ply wood to the wall fixing into the stud. Then mount the bespoke bracket to the ply. I used a rectangular piece which was long enough to span the studs.I've just bankrupted myself after buying an LG G5 after contemplating a G4, since I bought this house, literally a year ago this weekend.
What I didn't realise, is the wall I was going to mount it too, and all the walls in fact, have a slight cavity with plasterboard, for what I can only assume is for insulation purposes.
Where I want the TV, the stud is running directly through the middle, so I should be able to get the middle bolts in that. Will it be ok to use the spring toggle bolts for the sides. From some googling, it seems that quite a few people have mounted it entirely with the spring mounts, but I'd rather have some peace of mind knowing it's on a stud.
I think the gap between the brick and the plasterboard is only around 2" maybe 4", so I maybe able to some sort of long plug and bolt into the brick work?
I don't really want to cut the wall to bits if I have to, and certainly don't want some plywood behind it, as it won't sit flush.
Any ideas greatly welcome!
Well it turns out there is no cavity on that part of the wall and it was just dot and dab, so it is secured nicely on the wall. Although it is a tad high for my liking. I am awaiting a new center speaker to arrive, so when it does I will lower it a bit.
I have monitor audio BX5 floor standers for L/R. I have just bought a MA silver c250 7g but the colour I wanted was out of stock so awaiting new stock. Then when I have some more free cash or a deal comes up, I'll get matching silver frontsGet the best matching center you can same brand as left/right.
Yeah i don't like the MTM designs good call on larger four driver center I use something similar
