Mounting waterblock on a delided 4790K without IHS
Yes, imo you'll want one of those delid die guard type things to hold the CPU in the socket, if you simply use the pressure from the waterblock you're unlikely to get a flush contact across the surface of the core.
exactly that's what is bothering me. Is there such a guard available on market?
I think it's because of uneven pressure, the core is slightly off centre iirc. That's why I'd recommend a delid die guard.
Same here. My temps were higher with the IHS off. I had the naked Ivy kit for my block too. In the end I used Coolaboratory Liquid Pro on the core and refitted the IHS with gasket sealant. I lapped the IHS while it was off as well due to it being very convex.
Not clear if you were using the delid die guard?
Have tried both the Delid die guard and the EK naked Ivy kit and found both to be a complete waste of time. Over CLU and the IHS placed back on I saw 1c difference using the EK kit and the Delid die guard ran hotter.
Both are asking for bent socket pins even if you're really careful so I seriously wouldn't bother. Just stick to CLU or CLP and place the IHS back on.
Yeah i tried it back on Ivy, just couldnt get the pressure onto the die that the IHS manages to get.
