Mouse problems
12 Sep 2011
Hey guys I've been having problems with my mouse(blaze lazer mouse). Everytime I re-boot/re start windows I have to take it out of the usb put it in another one wait for windows to say it's not recognized and then put it back in another usb slot so it works, I tried looking for drivers for it but I can't seem to find any, any ideas on what to do?
Have you tried updating your motherboard drivers to the latest release?
Also what OS are you using and are there any recommended updates for your mosue via MS update?
Yeah I updated the drivers to the latest models and I've checked and re check everyday, theres no updates for the mouse
I'm using Win 7 64bit
I also have this problem intermmitently. Every so often after a reboot the mouse will not move but a restart sorts out the problem....
Not a problem so much but it would be nice to know if there is a simple fix?
I had this problem with my saitek mouse so i just uninstalled the mouse, shutdown , put the mouse into another usb then startup, Let windows install and all worked fine.
I have this problem very occasionaly as well, where I need to move the USB port I have my mouse plugged into before it registers.
