Hi guys,
When BT came and did the FTTP install I was a bit distracted. I hadn't realised they'd ran the ugly cable right down the front of the house and across my lovely 1930s ornate brick built porch......
I have a grey box outside, and then they've drilled a hole into the "under the stairs" cupboard.
Ideally I'd like to terminate the fibre into the attic and then relocate the modem up there, and run a cat5/6 down to the router.
Without being preached to about touching the CPE, is it a case of unplugging the modem and feeding the fibre back through the house? Or is there a connection outside to the grey box? Was the fibre from the grey box to the modem terminated on site, or is it just a fly lead?
Many thanks
Many thanks
